[SC300/400 GS300] Jak duze felgi mozemy wsadzic do Lexusa
Problemy z Przeniesieniem napędu dotyczące modelu SC
maxkow
Post by maxkow »
Niestety info w jezyku Angielskim
WHEELS & TIRES: When shopping for new wheels, take note of the wheel diameter, wheel width, bolt pattern, and wheel offset. Both SC coupes' bolt patterns are 114.3 x 5, stud design, with 12 x 1.5 threading and 60.1 bore. The stock offsets are +50mm. With larger and wider wheels some rubbing may occur on the fender lip or wheel well covers. This rubbing usually occurs when turning the front wheels all the way out or when the suspension bottoms out. Rubbing is attributed to several factors including: the drop height of the suspension, size of the tire sidewall, tire & wheel widths, and the wheel offset. The simple way of resolving a rubbing issue is by softly rolling the fender lip into a sharp wedge or shaving/lifting the wheel well covers where the rubbing occurs.
The largest wheel size that fits the SC wheel wells are 20"x9" in the front and 20"x10" in the rear. 19" wheels and below will fit the SC without rubbing issues in any assortment of wheel widths under 10 inches given the proper offset and tires. The widest tires ever attempted on the SC coupe are 275/30-ZR20 on a 20"x10" rim, 295/30ZR19 on a 19x11" rim, 295/35-ZR18 on an 18"x11" rim, and 315/35-ZR17 on a 17"x9.5" rim. All fitments were reported to work on the rear axles with no rubbing issues.
Below is a chart of tire sizes that are compatible with the SC and offer the similar outside diameters. Outside diameter is critial to maintain for the proper functioning of the anti-lock brakes, speedometer, and odometer instruments. These are just some of the tire sizes that fellow ClubLexus members are using on their cars. Some values are expressed as ranges of sizes. No size advertised below guarantees a perfect outside diameter match, it is recommended that you perform outside diameter calculations to ensure the tire is a good match. See more details below the chart...
L
TIRE
GUIDE WHEEL WIDTH
7.0 inch 7.5 inch 8.0 inch 8.5 inch 9.0 inch 9.5 inch 10.0 inch
D 16 inch 215-225 225-235 235-245 245-255 255-265 265-275 275-285
I 17 inch 215-225 225-235 235-245 245-255 255-265 265-275 275-285
A 18 inch 215-225 225-235 235-245 245-255 255-265 265-275 275-285
M 19 inch 215-225 225-235 235-245 245-255 255-265 265-275 275-285
E 20 inch 215-225 225-235 235-245 245-255 255-265 265-275 275-285
So let's shop for new tires for our new 17x9.5" Supra TT wheels. To calculate the outside diameter of a potential tire, 255/45ZR17 for example, you take the tire width (ie: 255mm), multiplied by the sidewall series given in a percentage (ie: 45% or 0.45), multiplied by two sidewalls per wheel, plus the diameter of the wheel in a common length (ie: 17-inches or 431.8mm). So you get [ 2 × (255mm × 0.45) ] + 431.8mm = 661.3mm outside diameter. Doing the same calculations for the stock 225/55ZR16 tires, we find that the stock outside is 653.9mm. 653.9mm is the value by which all the components operate. We can find the deviation from stock of our new Supra tires by dividing the new outside diameter by the old outside diameter. 661.3mm ÷ 653.9mm = 1.0113% or 1.13% deviation. Thus when your speedometer reads 60.0mph, you are actually travelling at a speed of 60.7mph. A better tire fitment would be 245/45ZR17 which, using the same formula, yields an outside diameter of 652.3mm. 652.3 ÷ 653.9 = 0.9975%, which is about 0.2% deviation. When your speedometer reads 60.0mph, you are now actually travelling 59.99mph, which is an acceptable difference. Now that you understand the principles, click here for a quick tool that calculates it for you!
Spacers: Another available mod for your wheels are wheel spacers. These are used to compensate for negative wheel offset. For instance, the SC coupe's stock offset is +50mm; However, Supra TT wheels have +38mm offset. Therefore you can use 5mm - 15mm spacers to correct the difference and line up your wheels better. It is strongly recommend you avoid 'universal spacers' in larger sizes than 5mm; However, there are some larger aftermarket spacers that are tested to work well with the SC300 and SC400.
H&R Springs makes wheel spacers designed for the SC coupe, which come with longer replacement wheel studs. H&R spacers come in the following thicknesses: 5mm, 15mm, 20mm, and 25mm. H&R 5mm spacers to not included lengthened studs because they are not necessary. With any spacer wider than 5mm, it is recommended that you use lengthened wheel studs.
Ralfx
Re: [lexus SC300/400 GS300] Jak duze felgi mozemy wsadzic do
Post by Ralfx »
Prośbę mam do właścicieli SC: Maxkow, Beemix, Malykrata i kto tam jeszcze miał. Zapodajcie wasze konfiguracje: rozmiar felgi, szerokość, ET, rozmiar opon, z podziałem na oś przednią i tylną.
Rozważam w najbliższym czasie (jest zima więc ceny niższe) zakup alusów.
W tym momencie mam upatrzoną konfigurację:
- przód 18x8 ET 45 opona 235/40 R18
- tył 18x9 ET 35 opona 265/35 R18 (lub 255/40)
Chcę jeszcze porównać czy ktoś z was może nie ma podobnych konfiguracji. Dobranie dobrych kół do SC to nie łatwa sprawa. Chce po prostu wiedzieć czy bedziemy giąć błotniki czy nie :)
Czuję że zaraz polecą dwa typy komentarzy :)
Jeden od Lexa w stylu "20 cali to jest minimum" odpowiadam: nie chce aż tak dużych kół bo nie stać mnie na opony :lol:
Drugi że auto straci na komforcie, spalaniu i przyspieszeniu - wiem, jestem świadom konsekwencji :)
Post by tomekb »
mysle ze sc na takich felgach bedzie konkretny a mocy nie straci zauwazalnie duzo na Polskie warunki jest i tak szybki pozatym twój motor można łatwo zaturbić a przy turbo takie ponki jaknajbardziej beda wskazane
Ralfx
Post by Ralfx »
Własnie pod kątem tego takie koło, potem na wiosne zawias, latem hamulce od supry TT i mam nadzieje że przyszła zima bedzie pracowita :) ale teraz odnosnie kół ;)
Post by tomekb »
mysle ze tylne beda za wysokie ciut jak wsadzisz zawias i trzeba bedzie blotniki naginac ale to nie problem mam kolege który robi to rekami :)
maxkow
Post by maxkow »
ja w swoim SC mialem przod 8,5J 18'' ET45 opona 235/40 tył 9,5J 18'' ET 35 opona 245/40 i nic nie obcieralo , mysle ze o jeden rozmiar szersze opony by jeszcze weszły, tak samo jak i 10J mozliwe ze wtedy trzeba by moze troche nadkola (ranty wew) oszlifowac.
Ralfx
Post by Ralfx »
Max a jak to wyglądało w tylnym nadkolu? Flega niby to samo ET ale szersza o pół cala czyli bardziej wystaje na zewnątrz. Jednakże opone miałeś węższą. Jak oceniasz na oko da rade zapakować 265 na 9J czy będzie trzeć opona ?
Lex
Post by Lex »
Ralfx wrote:Czuję że zaraz polecą dwa typy komentarzy :)
:acute: hehehe a no polecą bo taka jest prawda to są rady z których możesz skorzystać ale nie musisz ale na pewno pomogą zaoszczędzić czas i pieniądze
"20 cali to jest minimum" miałem na myśli model GS 2gen. i chyba ciężko się z tym nie zgodzić
wymiary podane przez maxa są prawie idealne ja wybrał bym mniejsze ET czyli ET35 na przód i mniejsze na tył bo jak widać na focie SC maxa przód i tył jest mocno schowany w nadkolu mam ten sam problem w moim GS z przodu jest ET35 i idealnie felga z oponą licuje się z nadkolem a tył mam mocno schowany w nadkole i niestety będę musiał ratować się dystansem .
model SC to spore auto więc 19" wystarczy dla zachowania równowagi (8,5" przód) i (10" tył) opony naciągnięte
"bo nie stać mnie na opony" i tu się kolego grubo mylisz , za 18" czasami wołają przesadzoną kasę bo to tz. popularniak ilościówka i zawsze zejdzie bez względu jak by nie była droga , tego natomiast nie można powiedzieć o oponach i felgach w roz. 19" można to chwycić w rozsądnych pieniądzach
"komfort , spalanie , przyspieszenie" konsekwencje ? w warunkach miejskich i normalnego codziennego użyt. niema żadnych to kompletne bzdury zazwyczaj opowiadane przez bajko-pisarzy no chyba że zamierzasz tłuc nowe światowe rekordy czasowe na specjalnie przystosowanych do tego torach takich jak High Speed Ring , Daytona Superspeedway czy Monza :sarcastic:
jeśli twoja decyzja już zapadła co do roz. felgi 18" to tragedii nie będzie tylko pamiętaj w przypadku 18" zapomnij o modelach z rantem wyglądają zabawnie przy tak sporym aucie , ramię felgi powinno być długie (przykład) Image aż do opony to da efekt wizualny i pozwoli zachować równowagę małej felgi ze sporym nadwoziem , masz rację czas jest jak najbardziej odpowiedni na chwycenie w dobrej kasie miłego kompletu na lato
janasek
Model Lexusa: SC 400
Post by janasek »
Lex masz rację. Ja planuję na lato 19 cali i faktycznie można felgi i opony chwycić w naprawdę dobrych cenach. Jednak nadal zastanawia mnie dlaczego odradzasz rant? Bo ja właśnie bym chciał z polerowanym rantem - dużo lepiej taka felga wygląda. A ramie faktycznie im dłuższe tym lepsze, ale rant tutaj moim zdaniem też pasuje. :)
Też pewni będę musiał zastosować dystanse bo kupic komplet felg z różnymi ET/szerokościami felg to już jest droższa sprawa.
Luxusem jadę... :)
legato97
Post by legato97 »
NIe jest tak zle z roznymi et, masz czas sie rozejrzec, ale zgadzam sie z lexem, ramie do opony wizualnie ladnie powieksza fele w 19, u mnie jest 8.5 et 38 i 9,5 et 45, dystanse nie potrzebne, felgi wygladaja ladnie rowno, wiec moze to jakas opcja takze dla SC
Return to “SC”
