W toyocie Altezzie wyglada to tak :
A01A - 3.916 Open Centre
A01B - 3.916 Torsen LSD
A02A - 4.083 Open Centre
A02B - 4.083 Torsen LSD
Tak więc "B" oznacza LSD.
A jak to wyglada w IS200 ??
This is a common question, regarding how to tell if a particular IS200 has a limited-slip diff or not. This can be tricky, e.g. Sport models should have them, but it's not always obvious if a car is a Sport or is an S/SE with added bits.
The sure way to tell is to check the manufacturer's VIN plate, located on the bulkhead at the back of the engine bay. Here's a picture of mine :
Guests cannot see images in the messages. Please register to forum by clicking here to see images.
The bottom line is the relevant one here. This is a coding that represents the paint code/trim/transmission etc. The specification of the "axle" is represented by the third group of characters. It will say either A02A or A02B. If it says "A" it's an open diff, and "B" means it's an LSD. Mine says "A02B" so it has an LSD.
Just for interest, on mine the first bit is the paint code (1C0 - Platinum Ice), I don't know what the second bit is for, think it's the trim (LB20), the third bit is the "axle" (above), and the fourth bit is the gearbox (J160 manual gearbox).
Of course, all this is about whether your car has a factory-fit LSD. It's possible that someone could have changed the diff as an after-market modification.
pokaż tą karte, jak ona wygląda? też mam od groma dziwnych książeczek i dok. ASO od autaTravis wrote:ja mam takie oznaczenia:
REAR DIFFERENTIAL 013J F19SX 3.909 LSD
Tak jest w karcie pojazdu która była dołączona przy sprzedaży auta...
forest wrote:pokaż tą karte, jak ona wygląda? też mam od groma dziwnych książeczek i dok. ASO od autaTravis wrote:ja mam takie oznaczenia:
forest wrote:Travis, czyli szpere masz...?
