IS200 vs IS300 shroud fan
mi16
Post by mi16 »
Hello.
I am from Slovakia, and I have a big problem with my expansion bottle .... So I have to buy a new one.... the biggest problem is, that i cannot find the shroud for is200 only for is300... my opinion is that they are not the same... So question is, when i buy that from is300 it will could be fit without any problem or?..... you can write in polish, I understand quite well, but i have a problem with writing in your languge, so i decided to use English. Thanks :)
mi16
Re: IS200 vs IS300 shroud fan
Post by mi16 »
or in your language using google translate
Hello.
Jestem ze Słowacji, i mam wielki problem z moim zbiorniku wyrównawczym .... Więc muszę kupić nowy ....Największym problemem jest to, że nie mogę znaleźć osłonę dla IS200 tylko dla IS300 ... moja opinia jest taka, że ​​nie są one same ... Więc pytanie jest, kiedy kupić, który od IS300 będzie można bez problemu dopasować lub? ..... można pisać w języku polskim, rozumiem bardzo dobrze, ale mam problem z pisaniem w languge, więc postanowiłem użyć angielskiego. Dzięki :)
mi16
Post by mi16 »
nikto newie?
dS
Model Lexusa: RX500h / GR Yaris
Post by dS »
michuu
Model Lexusa: Prius
Post by michuu »
mi16
Post by mi16 »
Fan shrouds are definitelly different. The position of cap on is200 is on the other side as is300. I know about toyodyi, but almost 150euros its too much for a bit of plastic. I already found something on the cech website, it is almost for 45e, it isnt so much. http://www.e-cat.cz/c-1409_196571_20458 ... atory.html But i think it is for is300. I sent an email to this company, but i have to wait for a picture of that car part, what i need.
I prefer to buy a new one, because i already bought one from allegro, and there was a really similar problem what i have on my expansion bottle.
Thanks for help
Osłony wentylatora są definitelly inaczej. Położenie nakrętki na IS200 jest po drugiej stronie, jak IS300. Wiem o toyodyi, ale prawie 150euros jej zbyt wiele dla kawałka plastiku. I już znalazłem coś na stronie Cech, jest prawie na 45e, to nie jest tak dużo. http://www.e-cat.cz/c-1409_196571_20458 ... atory.html Ale myślę, że to jest dla IS300. Wysłałem e-mail do tej firmy, ale muszę czekać na obraz tej części samochodu, co potrzebne.
Wolę kupić nowy, bo ja już kupiłem z allegro, i tam był bardzo podobny problem, co mam na moim zbiorniku wyrównawczym.
Dzięki za pomoc
dS
Post by dS »
Ceny podane w ToyoDIY odpowiadają miej więcej temu co trzeba zapłacić w salonie Lexusa.
Korek o którym piszesz to odpowietrzenie i nie ma większego znaczenia gdzie on jest. W IS300 puszka filtra powietrza jest po prawej stroni i korek ten schowany był by pod kanałem dolotowym dlatego jest w innym miejscu. Tym czym powinieneś się martwić to mocowanie, a te powinno być takie samo bo obydwa modele mają taką samą chłodnicę.
mi16
Post by mi16 »
Yes, i know that heater is the same in is200 as in is300. So the air pipe for filter is the only reason why I was afraid. So you want to say if i buy is300 shroud it would not be any problem with fiting. Will be there enough place among the is300 shroud and is200 air pipe?
Tak, wiem, że grzejnik jest ten samy w is200 jak w is300. Więc rury powietrza do filtra jest jedynym powodem, dla którego się boi. Więc chcesz powiedzieć, jeśli mogę kupić IS300 całun to nie byłoby żadnego problemu z okucia. Będzie tam wystarczająco dużo miejsca pomiędzy IS300 shroud i IS200 powietrza osłony rur filtra?...
dS
Post by dS »
Ja na twoim miejscu szukał bym używanego zbiornika z IS200 wtedy będziesz miał 100% pewności ze będzie pasował, bo z częściami nie oryginalnymi jest ten problem że nie zawsze pasują idealnie. A z wersją od IS300 nie ma pewności ze przewód odpowietrzający nie będzie minimalnie przeszkadzał w zamontowaniu kanału dolotu powietrza.
IS300
mi16
Post by mi16 »
I already bought one from allegro. But expansion tank has a similar problem. So maybe I will try to make a one from both of them or maybe i will buy some universal expansion tank. I know, that it would not look like original, but maybe not be as worst as I think , What do you think? http://www.ebay.com/itm/Weapon-R-826-11 ... 0558323811
Ja już kupiłem z allegro. Ale zbiornik wyrównawczy ma podobny problem. Więc może postaram się zrobić jedną z obu z nich, a może i będzie kupić jakiś uniwersalny zbiornik wyrównawczy. Wiem, że nie będzie wyglądać jak oryginał, ale może nie być tak najgorzej, jak myślę, co o tym sądzisz?
Return to “IS mk1 1998-2005”
