SC400-filtry kabinowe
Problemy dotyczące modelu SC
prosperopro
Model Lexusa: LS400 UCF11
Re: SC400-filtry kabinowe
Post by prosperopro »
w komplecie sa 2 filtry :)
TOYOTA LEXUS LS400 ®
passat1978
Model Lexusa: gs 300
Post by passat1978 »
Ja w GS mk I mam taki jak w linku z ebay ale na poczatek wrzesnia gość w jednym sklepie powiedzial,mi ze załatwi mi ten filtr za ok 70-80 zł wiec czekam.
Części do LEXUS GS 300 KMI
NR 790462651 Lub PW
ryszolo
Model Lexusa: SC400, RX450h+
Post by ryszolo »
Rzeczywiście w GS300 filtry kabinowe są identyczne jak w SC300 i SC400
Poniżej częściowa lista modeli do , których pasują:
Notes
Important part details Year Make Model Trim Engine
Part Note: CHARCOAL ... 2000 Lexus SC300 Base Coupe 2-Door 3.0L 2997CC l6 GAS DOHC Naturally Aspirated
Part Note: CHARCOAL ... 2000 Lexus SC400 Base Coupe 2-Door 4.0L 3969CC V8 GAS DOHC Naturally Aspirated
Part Note: CHARCOAL ... 1999 Lexus SC300 Base Coupe 2-Door 3.0L 2997CC l6 GAS DOHC Naturally Aspirated
Part Note: CHARCOAL ... 1999 Lexus SC400 Base Coupe 2-Door 4.0L 3969CC V8 GAS DOHC Naturally Aspirated
Part Note: CHARCOAL ... 1998 Lexus SC300 Base Coupe 2-Door 3.0L 2997CC l6 GAS DOHC Naturally Aspirated
Part Note: CHARCOAL ... 1998 Lexus SC400 Base Coupe 2-Door 4.0L 3969CC V8 GAS DOHC Naturally Aspirated
Part Note: CHARCOAL ... 1997 Lexus GS300 Base Sedan 4-Door 3.0L 2997CC l6 GAS DOHC Naturally Aspirated
Part Note: CHARCOAL ... 1997 Lexus SC300 Base Coupe 2-Door 3.0L 2997CC l6 GAS DOHC Naturally Aspirated
Part Note: CHARCOAL ... 1997 Lexus SC400 Base Coupe 2-Door 4.0L 3969CC V8 GAS DOHC Naturally Aspirated
Part Note: CHARCOAL ... 1996 Lexus GS300 Base Sedan 4-Door 3.0L 2997CC l6 GAS DOHC Naturally Aspirated
Part Note: CHARCOAL ... 1996 Lexus SC300 Base Coupe 2-Door 3.0L 2997CC l6 GAS DOHC Naturally Aspirated
Part Note: CHARCOAL ... 1996 Lexus SC400 Base Coupe 2-Door 4.0L 3969CC V8 GAS DOHC Naturally Aspirated
Part Note: CHARCOAL ... 1995 Lexus GS300 Base Sedan 4-Door 3.0L 2997CC l6 GAS DOHC Naturally Aspirated
Part Note: CHARCOAL ... 1995 Lexus SC300 Base Coupe 2-Door 3.0L 2997CC l6 GAS DOHC Naturally Aspirated
Part Note: CHARCOAL ... 1995 Lexus SC400 Base Coupe 2-Door 4.0L 3967CC V8 GAS DOHC Naturally Aspirated
Part Note: CHARCOAL ... 1994 Lexus GS300 Base Sedan 4-Door 3.0L 2997CC l6 GAS DOHC Naturally Aspirated
Part Note: CHARCOAL ... 1994 Lexus SC300 Base Coupe 2-Door 3.0L 2997CC l6 GAS DOHC Naturally Aspirated
Part Note: CHARCOAL ... 1994 Lexus SC400 Base Coupe 2-Door 4.0L 3967CC V8 GAS DOHC Naturally Aspirated
Part Note: CHARCOAL ... 1993 Lexus GS300 Base Sedan 4-Door 3.0L 2997CC l6 GAS DOHC Naturally Aspirated
Part Note: CHARCOAL ... 1993 Lexus SC300 Base Coupe 2-Door 3.0L 2997CC l6 GAS DOHC Naturally Aspirated
Brand: DENSO
Manufacturer Part Number: 453-1003
Sub Type: Cabin Air Filter
prosperopro
daj namiar na przyszlosc ? choc ja z USA 3 szt. zamowilem to moze taniej wyjdzie jk regenerowac zuzyte ;)
Wombat
Model Lexusa: LS 400
Post by Wombat »
a co z tym płynem który jest w układzie klimatyzacji ?
żeby była jasność - nie pisze o czynniku w układzie klimatyzacji tylko o buteleczce z napisem "Aromatizer" u mnie chyba produkcji Castrol-a to jest.
to jakiś odsmradzacz/dosmradzacz ?
nawet naklejka jest na kick panelu fabryczna "Aircondition with Aromatizer"
Wygląda jak część wymienna pusta obecnie w połowie u mnie.
________________________________________________________
a LS łyka Image
uho50
Model Lexusa: Gs 300
Post by uho50 »
Odnośnie filtra kabinowego w gs 300 mk I jest jakis sposob żeby go wyciągnąć??
Poprzedni mechanik mi wymienil i chyba wepchnoł na sile i teraz nie można go wyjać:/ czy konieczna bedzie operacja zdjęcia deski i wtedy wyjęcia go??
Reason: dlaczego piszesz o tym samym problemie w 2 różnych tematach?? robisz bałagan!!!
Drugie oko w mojej głowie
:LEXUS: :LEXUS: :LEXUS: :LEXUS: :LEXUS: :LEXUS:
Return to “SC”
